  2. Allegro X Capture CIS
  3. Capture to Allegro: How to exclude a component from transfer...
  • State Verified Answer
  • Subscribers 52
  • Views 2977
Capture to Allegro: How to exclude a component from transfer to PCB
eddoh
eddoh over 1 year ago
Hi everybody.
I have in my Capture schematic  a virtual resistor i am using just for simulation,
I'd like to avoid to have it in the components I need to route (and handle the related DRC)
Is there a clean way to do this?
Deleting the Footprint field raises error, tried using properties NO_PCB, EXCLUDE_FROM_PCB,  with no luck
Thanks!
Ema
  • oldmouldy
    oldmouldy over 1 year ago +3 verified
    The PSpice elements use PSpiceOnly set to TRUE to not be in the netlist and NETLIST_IGNORE set to TRUE (Or YES, you will need to check which works) is more "general purpose"
  • oldmouldy
    +1 oldmouldy over 1 year ago
    • Vote Up +3 Vote Down
  • eddoh
    0 eddoh over 1 year ago in reply to oldmouldy
    thank you so much! I knew there was a way. google and AI gave me a gazillion of wrong and nonsensical answers..
    have a laugh at this Gemini wrong answer:
    "I understand your skepticism, and I apologize if the term "DON'T TOUCH" sounds informal or made up. However, I assure you that "DON'T TOUCH" is indeed the correct and official property name in Cadence OrCAD Capture for preventing a component from being transferred to Allegro PCB Editor."
  • eddoh
    0 eddoh 7 months ago in reply to oldmouldy
    oldmouldy  is there a way to do the same with a single pin (which in Capture I use to connect a stimulus for simulation, therefore it is a PSPICE simulation construct with no footprint match) I tried PSPICEONLY and NETLIST_IGNORE (TRUE or YES) but I always get (SPMHGE-82): Pin numbers do not match between symbol and component when I try to place the footprint in the layout.
    Thanks! :)
  • RFinley
    0 RFinley 6 months ago in reply to eddoh
    I have found that a symbol having no pins is reliably not exported in the netlist but can be used to add things like mounting hardware to the BOM.
