  2. Allegro X Capture CIS
  3. Standard Bill of Material Template
  • State Verified Answer
  • Subscribers 51
  • Views 3217
Ben Bina
Ben Bina over 1 year ago
Hi
In OrCAD capture X 24.1 in "Standard Bill of Material" tool I see a Template on top, How can I edit and add more BoM template.
  • TechnoBobby
    TechnoBobby over 1 year ago +2 verified
    Hi Ben Bina , To add and save a new BOM template in Capture, follow these steps: 1. In the Standard Bill of Materials dialog, add the required properties under the Output Format section and arrange them…
  • TechnoBobby
    +1 TechnoBobby over 1 year ago
    Hi Ben Bina ,
    1. In the Standard Bill of Materials dialog, add the required properties under the Output Format section and arrange them as needed.
    2. Enable any relevant options like Keyed, Export to Excel, etc.
    3. In the Template Name field at the top, type a name for your custom template (e.g., My_BOM_Template).
    4. Click OK to save the template.
    If you’re looking to share this template with others, you can refer below article on ASK portal:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009xw9EEAQ
    Hope this helps!
    • Vote Up +2 Vote Down
  • PP202506235415
    0 PP202506235415 over 1 year ago
    To edit a BoM template in OrCAD Capture X 24.1, open the Standard BoM tool, select the template from the top dropdown, then click the edit icon to modify it.
    To add a new template, choose "New Template" or edit an existing one and use "Save As" to save it under a new name. It will then appear in the template list.
  • PP202506235415
