  2. Allegro X Capture CIS
  3. Troubleshooting Missing Voltage Sources in Netlists
  • State Verified Answer
  • Subscribers 45
  • Views 1828
LC202506035949
LC202506035949 5 months ago
If you're experiencing issues with voltage sources not appearing in your netlist, make sure to attach a power symbol to each voltage source. Also, rename each power symbol appropriately if you have multiple voltage sources in your design.
By attached a power symbol, it treats it as a global net identifier. Without this, the tool might not recognize the voltage source as connected to anything meaningful.
Example:
In the schematic below, a 5V voltage source is correctly connected to a power symbol named "5V". This ensures the voltage source is properly included when generating the project netlist.
Hope this helps anyone dealing with this issue! Slight smile
  • rg13
    +1 rg13 5 months ago
    That's useful info.
    However, if someone is looking for more information on power/ground connections, following article from ASK portal can also be referred:
    Article (11052332) Title: How to connect invisible POWER/GROUND pins to specific PWR/GROUND nets in Capture
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nYC6EAM
    Article (20495691) Title: How to find all visible unconnected power pins
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AEGeXEAX
    Article (11700698)
    Title: How can I check all components, nets, and connections of every net in my design?
    URL: support.cadence.com/.../ArticleAttachmentPortal
    • Vote Up +2 Vote Down
  • LC202506035949
    0 LC202506035949 5 months ago in reply to rg13
    Thanks rg13 for the contribution of helpful info! Slight smile
  • HH20250923150
    0 HH20250923150 3 months ago in reply to LC202506035949
    Oh, I also thanks for this info
