  2. Allegro X Capture CIS
  3. After annotate facing issues.
  • State Suggested Answer
  • Answers 1
  • Subscribers 49
  • Views 1680
Edit slide getting closed
Edit slide getting closed over 1 year ago
Hi All,
Urgent Support need.
I recently annotated my schematics, but when I open Edit Object Property, I see both the old and new reference numbers for the same part. Has anyone encountered this issue before? How can I resolve it?
  • TechnoBobby
    TechnoBobby over 1 year ago +1 suggested
    Hi Edit slide getting closed , Here’s how you can address it: Option 1 – Keep the occurrence value (the yellow one) Use Accessories > Transfer Occ. Prop. to Instance > Push Occ. Prop into Instance. This…
  • TechnoBobby
    0 TechnoBobby over 1 year ago
    This will copy the occurrence value into the instance property so they match.
    Option 2 – Remove the occurrence value
    Use Design > Remove Occurrence Properties.
    This will remove the occurrence properties, leaving only the instance-level reference.
    You can then re-run annotation in your preferred mode:
    • Instance mode: One reference per logical part (works well if blocks aren’t reused).
    • Occurrence mode: Unique reference per block occurrence (needed if blocks are reused).
    Below is an application note on ASK portal that explains the difference between instance and occurrence mode of annotation in detail.
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000050Q9EAI
    Hope this helps!
  • Edit slide getting closed
    0 Edit slide getting closed over 1 year ago in reply to TechnoBobby
    Thanks much. Problem Solved.
