  2. Allegro X Capture CIS
  3. Back annotation via a TCL Script
  • Subscribers 50
  • Views 1666
Maxime1998
Maxime1998 over 1 year ago
Hello everyone,
I’m currently trying to perform back annotation using a TCL script. I have identified the four commands used for back annotation, but I’m not able to apply the changes to my schematic.
I believe I need to use the “update schematic” step, but I would like to execute it via a command in my TCL script. Does anyone know the command or function to directly perform “update schematic” within a TCL script?
Thanks in advance,
Maxime
  • CadAP
    0 CadAP over 1 year ago
    Maxime1998
    Can you share those four commands?
    Meanwhile you can try the below command:
    pstswp.exe -pst -d <designName> -n <allegroDirectory> -c <configFIll Path> -v 3 -l 31 -s "" -j <FootPrintProperty> -hpath "HPathForCollision"
    Here
     -d :- to choose the Capture design file.
     -n :- to select the netlist directory.
     -s :- To select path for saving swp file.
     -c :- Allegro.cfg is the configuration file. One of the file available from .zip file.
    Hope it helps.
  • Maxime1998
    0 Maxime1998 over 1 year ago in reply to CadAP
    Yes, here are those command:
    exec "C:/Cadence/SPB_17.4/tools/bin/genfeedformat.exe" -x -b $rep_board -o $rep_schema
    puts "Extract logic from board"
    exec "C:/Cadence/SPB_17.4/tools/bin/pstswp.exe" -pst -d $rep_dsn -n $rep_schema -c "C:/Cadence/SPB_17.4/tools/capture/allegro.cfg" -v 3 -w -l 255 -s "" -j "PCB Footprint" -hpath "HPathForCollision" -backwd
    puts "Netlisting the design"
    exec "C:/Cadence/SPB_17.4/tools/bin/pstswp.exe" -swp -d $rep_dsn -n $rep_schema -s $rep_swp -c "C:/Cadence/SPB_17.4/tools/capture/allegro.cfg" -hpath "HPathForCollision" -backwd
    puts "generating backannotation file"
    exec "C:/Cadence/SPB_17.4/tools/bin/cmfeedback.exe" -overwrite -rZ $rep_xml physical in $rep_DCF $rep_cmdbview
    puts "Extracting Constraint Changes"
    These are the commands that appear in the session log. I can see that they detect the differences, but they don’t make any changes in my design. One of them looks similar to the command you gave me, but from what I understand, the third command is supposed to generate the .swp file.
    Than you very much,
    Maxime.
