  2. Allegro X Capture CIS
  3. OrVAD X Capture License warning
  • State Verified Answer
  • Subscribers 50
  • Views 2174
JuriVi
JuriVi over 1 year ago
Hello everybody,
I work with OrCAD X Professional Plus 25.1 P001. I have also the corresponding license for this release.
By starting of Capture thge warning appears:
"This feature is available only with OrCAD X License. Get a valid or renew existing subscription to access the feature".
By Clicking of OK, Capture works as usualy.
But how can I fix this warning?
  • Jeet
    Jeet over 1 year ago +1 verified
    This pop-up notification generally occurs when you are not having a valid cloud license. If you want to disable the popup perform the below steps- Navigate to Options > Extended Preferences . Select…
  • Jeet
    +1 Jeet over 1 year ago
    1. Navigate to Options > Extended Preferences.
    2. Select the Cloud option in the left pane.
    3. Deselect the Connect To Cloud On Application Launch check box in the right pane.
            4. This will disable the login popup for Cloud services in subsequent launches of Capture CIS.
    Let me know how it goes for you after performing the steps ?
  • JuriVi
    0 JuriVi 11 months ago in reply to Jeet
    It helps.
    Thank you
