  2. Allegro X Capture CIS
  3. HOME environment variable clashes with other software
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 1356
FD202512143017
FD202512143017 11 months ago
Cadence depends on the env var HOME to store user config. The issue is, many programs expect HOME to point to the users home directory, however, Cadence has hijacked the HOME variable. Is there an alternative env var I can use that Cadence will look at first, like CADENCE_HOME or something along those lines?
  • rg13
    rg13 11 months ago +1 suggested
    You can create a batch file (.bat) to invoke the tool and set HOME variable location to somewhere else which is not being used by other tools.
  • rg13
    0 rg13 11 months ago
