  2. Allegro X Capture CIS
  3. Creating a symbol for 61 sections and 10000+ pins using...
  • State Verified Answer
  • Subscribers 50
  • Views 1662
Creating a symbol for 61 sections and 10000+ pins using New Part Creation Spreadsheet, why I can't enter the section after pin 4096?
MH202512174259
MH202512174259 11 months ago
Sorry but for some reason, I cannot upload any images.
I set Number of Sections to 61, but I can't enter the section number for the pins after pin 4096, they can only be entered by 'A'.
The Capture CIS version I used is 17.4, Could this be a version issue?
Thanks.
  • Jeet
    Jeet 11 months ago +1 verified
    Add rows in the spreadsheet before you can add the pins and perform the following steps: Click on Add Pins to add the pins exceeding 4096 and click OK . For example, if the total number of pins…
  • Jeet
    +1 Jeet 11 months ago
    1. Click on Add Pins to add the pins exceeding 4096 and click OK.
    For example, if the total number of pins in the part is 4100, you need to add 4 (4100 – 4096 = 4) more pins.
    1. Select Numeric under Part Numbering.
    1. Add the number of sections as needed and fill the other columns accordingly.
    Let me know how it goes for you after performing the steps?
  • MH202512174259
    0 MH202512174259 11 months ago in reply to Jeet
    Hi Jeet,
     Your steps solved my problem.Very appreciated for your help
