  2. Allegro X Capture CIS
  3. ORCAP-1616 INVALID REFERENCE
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 1381
TM202601138148
TM202601138148 10 months ago
Using Allegro Design Entry CIS 17.4. I created a heterogenous part with 12 sections in a library and I am using it on my schematic. I placed 4 instances of the part. Reference(s) are: J301A, J301B, J302A, and J302B.  Designators are numeric (-1 thru -12). Each section has 16 pins. I manually changed the part reference value to "J301A" etc. and Orcad auto-fills the designator as it should.
DRC keeps coming up with ORCAP-1616 "Reference is invalid for this part".
What am I doing wrong?
  • TechnoBobby
    0 TechnoBobby 10 months ago
    Hi TM202601138148 ,
    The Reference you assign must always end with a number.
    When the reference ends numerically, Capture can correctly build the Part Reference:
    • For numeric sections: J301-1, J301-2, etc.
    • For alphabetic sections: J301A, J301B, etc.
    If you try to make the Reference itself end with a letter (like J301A), Capture treats it as invalid. This causes conflicts and leads to DRC errors such as ORCAP‑1616.
    Hope this helps!
