  2. Allegro X Capture CIS
  3. Pregiven Categories Cannot Be Used Properly in Capture 25...
  • State Verified Answer
  • Replies 8
  • Subscribers 52
  • Views 3785
Pregiven Categories Cannot Be Used Properly in Capture 25.1
EY202602119834
EY202602119834 9 months ago
 Firstly I am a newbie in Cadence products. By using my school mail I have taken 180-day OrCAD X Professional Plus license and I am trying to implement an IC which specifically is TPS62132RGTR to my project. I tried to find and place the related component by using SamacSys, Ultra Librarian and Snap Magic for many times. However, I always took the same error: ERROR(ORCAP-2472) Failed to place symbol instance for model "296-29936-2-ND" because library " does not exist. I searched on the web and the Cadence Troubleshooting Information. However i could not find the exact solution neither on the web nor Cadence Troubleshooting information. Then i tried to place different components such as resistors, capacitors, inductors via pregiven categories PSpice, SamacSys, Ultra Librarian and Snap Magic none of them are replaced and in the all attemptions I have taken nearly same error message, the only thing different was the model name.
 Are there any one who dealt with this problem before? What can I do to deal with my problem, any ideas?
  • JCTEYSSIER0
    JCTEYSSIER0 9 months ago in reply to EY202602119834 +1 verified
    Space should be considered as a field separator, so yes it can be a problem. Try to use an other location without space
  • JCTEYSSIER0
    Good day to you
  • Jeet
    0 Jeet 9 months ago
    I am able to place TPS62132RGTR component on schematic page as shown below without getting any error -
    Which version of the tool you are using, I am using SPB 25.1 ISR 1.
    Also, can you share session log window screenshot ?
  • EY202602119834
    0 EY202602119834 9 months ago in reply to Jeet
    I am using ISR 2, specifically 25.1 S020, and I could not share my session log screenshot because of an error that comes from this site. However i copied and pasted my session log and for my privacy concerns I changed mu user name as "<user_name>" in the shared session log.
    Restarting Sync utility
    INI File Location:C:\Users\<user_name>\AppData\Roaming\SPB_Data\cdssetup\OrCAD_Capture/25.1.0/Capture.ini
    Component Cache:1
    File C:\Users\<user_name>\Documents\Library\orcadcaptureolb inaccessible.
    Could not find C://Users//<user_name>//AppData//Roaming//SPB_Data//cdssetup//OrCAD_Capture//25.1.0//temp//downloaded_parts//SamacSys_part_1771186858//TPS62132RGTR//Capture/TPS62132RGTR.OLB
    Could not find C://USERS//<user_name>//APPDATA//ROAMING//SPB_DATA//CDSSETUP//ORCAD_CAPTURE//25.1.0//TEMP//DOWNLOADED_PARTS//SAMACSYS_PART_1771186858//TPS62132RGTR//CAPTURE/TPS62132RGTR.OLB
    INFO(ORDBDLL-1229): XMATIC : Creating Library..C://USERS//<user_name>//APPDATA//ROAMING//SPB_DATA//CDSSETUP//ORCAD_CAPTURE//25.1.0//TEMP//DOWNLOADED_PARTS//SAMACSYS_PART_1771186858//TPS62132RGTR//CAPTURE/TPS62132RGTR.OLB
    INFO(ORDBDLL-1229): XMATIC : Saving Library..C:\USERS\<user_name>\APPDATA\ROAMING\SPB_DATA\CDSSETUP\ORCAD_CAPTURE\25.1.0\TEMP\DOWNLOADED_PARTS\SAMACSYS_PART_1771186858\TPS62132RGTR\CAPTURE\TPS62132RGTR.OLB
    INFO(ORCAP-2479): "Downloaded the following library to place the symbol instance of the model, 'TPS62132RGTR':
    'C:/Users/<user_name>/AppData/Roaming/SPB_Data/cdssetup/OrCAD_Capture/25.1.0/downloaded_parts/SamacSys/capture/TPS62132RGTR.OLB'
    ERROR(ORCAP-2472): Failed to place symbol instance for model 'TPS62132RGTR' because library '' does not exist.
  • JCTEYSSIER0
    0 JCTEYSSIER0 9 months ago in reply to EY202602119834
    Does <username> have space and/or special character (éèÖÀ&%µ# and so on)?
  • EY202602119834
    0 EY202602119834 9 months ago in reply to JCTEYSSIER0
    It does not have any special character, but it contains space, does the problem occurs of my user name?
  • JCTEYSSIER0
    +1 JCTEYSSIER0 9 months ago in reply to EY202602119834
