  2. Allegro X Capture CIS
  3. How to fix Errors ORCAP-2434 and ORCAP-2435 with a design...
  • State Suggested Answer
  • Answers 1
  • Subscribers 48
  • Views 2584
How to fix Errors ORCAP-2434 and ORCAP-2435 with a design that was done by an outside Contractor?
PAttardi
PAttardi 8 months ago
I have 3 designs that have these issues and need to fix it to be able to update the designs. I did see the ORCAP-2434 fix, but it seems that this is just a quick fix and I would like to get rid of the bad library link permanently.
ORCAP-2434 link WARNING(ORCAP-2434): Footprint 'smdcap' specified for instance C* is missing. Ensure 'smdcap' is in library path.
I also would have to guess that the ORCAP-2435 error is due to the bad library link as well and when I fix that one, it will fix this issue as well. I did check the schematic parts that have this additional issue and there are no hidden pins, and I can cross probe without issue and all pins and nets match.
My last question is how did this issue even happen and how do I make sure it does not happen again?
  • Jeet
    Jeet 8 months ago in reply to PAttardi +1 suggested
    Where are the libraries present is it present locally or on server ? ORCAP-2435 warning appears in the Online DRC even when the number of pins in the schematic symbol matches with the number of pins…
  • Jeet
    0 Jeet 8 months ago
    Are you using relative paths or absolute paths in Capture.ini ?
    ORCAP-2435 is a physical DRC and it comes when the number of pins in the schematic symbol does not match with the number of pins in the footprint.
    Read in detail about ORCAP-2435 Warning.
    Article (20495508) Title: WARNING(ORCAP-2435): Number of pins in footprint XXXXX and instance XXX does not match.
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • PAttardi
    0 PAttardi 8 months ago in reply to Jeet
    "Are you using relative paths or absolute paths in Capture.ini ?"
    What Line is this in the Capture.ini file? I do have links in the part Management and Allegro Footprints sections that point to my local CIS library that I mad and have been using for some time without issue.
    "ORCAP-2435 is a physical DRC and it comes when the number of pins in the schematic symbol does not match with the number of pins in the footprint."
    Yes, I know, but in this case, the pins in the schematic do match the pins in layout editor. I also checked for hidden pins and there are none that show up.
    "Article (20495508) Title: WARNING(ORCAP-2435): Number of pins in footprint XXXXX and instance XXX does not match."
    I will take a look and see if this will correct the pin mismatch issue.
  • Jeet
    0 Jeet 8 months ago in reply to PAttardi
    ORCAP-2435 warning appears in the Online DRC even when the number of pins in the schematic symbol matches with the number of pins in the footprint. This is because alphanumeric pin numbers are case sensitive, so it must be ensured that the pin number's casing should be same in the schematic symbol and the footprint and make sure that same named footprint is not present in the library path.
