  2. Allegro X Capture CIS
  3. How to replace Instance values of whole schematic using...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 1277
How to replace Instance values of whole schematic using Occurrence fields with TCL command or script.
abhisheklogic
abhisheklogic 8 months ago
I am using OrCAD Capture CIS 24.1 for schematic design.
I would like to copy values from the Occurrence tab (such as Manufacturer Part Number, Operating Temperature, etc.) to the Instance tab using a TCL command or script.
I want to avoid doing this manually, as the design contains more than 3000 components (over 300 BOM items).
I have attempted this at my end but have not been successful. Could you please assist me with this?
Looking forward to your response.
Thanks & regards,
Raj Kumar
Best Regards,
Raj Kumar
  • TechnoBobby
    0 TechnoBobby 8 months ago
    Hi Raj,
    Please try the below TCL script to copy all Occurrence properties to Instance across the entire design.
    It handles multiple occurrences by matching the Reference; you can tweak according to your DSN.
    I hope it helps!
    Note: Please create a backup of your design before running script.
    namespace eval ::capOcc2Inst {
    # Get property string value
    proc ::capOcc2Inst::GetProp {obj pName} {
    set pCS [DboTclHelper_sMakeCString $pName]
    set outCS [DboTclHelper_sMakeCString]
    $obj GetEffectivePropStringValue $pCS $outCS
    return [string trim [DboTclHelper_sGetConstCharPtr $outCS]]
    # Set property string value
    proc ::capOcc2Inst::SetProp {obj pName val} {
    $obj SetEffectivePropStringValue [DboTclHelper_sMakeCString $pName] [DboTclHelper_sMakeCString $val]
    # Copy Occurrence to Instance for a single part instance
    proc ::capOcc2Inst::ProcessPart {lPart} {
    # Skip non-parts
    if { [$lPart GetObjectType] != $::DboBaseObject_PLACED_INSTANCE } {
    return
    set occCount [$lPart GetOccurrencesCount]
    if {$occCount == 0} {
    puts "No occurrences - skipped"
    return
    # Pick correct occurrence
    set instRef [::capOcc2Inst::GetProp $lPart "Reference"]
    set lOcc [$lPart GetOccurrencesAtPos 0]
    if {$occCount > 1} {
    for {set i 0} {$i < $occCount} {incr i} {
    set cand [$lPart GetOccurrencesAtPos $i]
    if {[::capOcc2Inst::GetProp $cand "Reference"] eq $instRef} {
    set lOcc $cand
    break
    # Build list of all occurrence properties
    set occProps {}
    set lStatus [DboState]
    set iter [$lOcc NewEffectivePropsIter $lStatus]
    set pName [DboTclHelper_sMakeCString]
    set pVal [DboTclHelper_sMakeCString]
    set pType [DboTclHelper_sMakeDboValueType]
    set editable [DboTclHelper_sMakeInt]
    set lStatus [$iter NextEffectiveProp $pName $pVal $pType $editable]
    while {[$lStatus OK] == 1} {
    set name [DboTclHelper_sGetConstCharPtr $pName]
    set val [DboTclHelper_sGetConstCharPtr $pVal]
    # Ignore ID (instance doesn’t have ID)
    if {$name ne "ID" && $val ne ""} {
    ::capOcc2Inst::SetProp $lPart $pName $pVal
    delete_DboEffectivePropsIter $iter
    puts "Updated instance $instRef from occurrence"
    # Run function: iterate all selected objects
    proc ::capOcc2Inst::CopyOccToInst {} {
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lDesign [$lSession GetActiveDesign]
    if {$lDesign == $lNullObj} {
    puts "ERROR: No active design"
    return
    set schIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    set lView [$schIter NextView $lStatus]
    while {$lView != $lNullObj} {
    set lSchematic [DboViewToDboSchematic $lView]
    set pageIter [$lSchematic NewPagesIter $lStatus]
    set page [$pageIter NextPage $lStatus]
    while {$page != $lNullObj} {
    set partIter [$page NewPartInstsIter $lStatus]
    set lPart [$partIter NextPartInst $lStatus]
    while {$lPart != $lNullObj} {
    ::capOcc2Inst::ProcessPart $lPart
    delete_DboPagePartInstsIter $partIter
    delete_DboLibViewsIter $schIter
    puts "Done copying all Occ to Inst for selected parts."
