  2. Allegro X Capture CIS
  3. How can I change part properties in a library using tcl...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 1614
How can I change part properties in a library using tcl commands?
RT202604073158
RT202604073158 7 months ago
I am trying to automate a conversion of a long list of passive part numbers into parts in a library. I am already able to take a part that has appropriate symbol and set of properties and copy it into the library. I need to, for example, take a copied-in template of a 100 Ohm resistor and update the part number, value, footprint, etc. in the library permanently to make a similar 1 kOhm resistor. I just can't seem to figure out exactly how to access the properties and change them.
  • TechnoBobby
    0 TechnoBobby 7 months ago
    Hi RT202604073158 ,
    When updating properties at library level, it’s important to use the correct object type based on the property being modified.
    Package level properties (for example, PCB Footprint) must be updated using the DboPackage APIs, while part level properties (such as Value) should be updated using DboLibPart APIs.
    Below is a sample script demonstrating this. You can modify it further based on your specific requirements.
    Hope it helps!
    proc UpdatePassivePartAndPackage {libName partName newValue newPartNumber pkgName newPCBFootprint} {
    set NullObj NULL
    set lStatus [DboState]
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    # Open library
    set libCStr [DboTclHelper_sMakeCString $libName]
    set lLib [$lSession GetOpenLib $libCStr $lStatus]
    if {$lLib == $NullObj} {
    puts "ERROR: Unable to open library: $libName"
    return
    # Update PART properties (VALUE, PART_NUMBER)
    set partIter [$lLib NewPartsIter $lStatus]
    set lPart [$partIter NextPart $lStatus]
    set partFound 0
    while {$lPart != $NullObj} {
    set pNameCStr [DboTclHelper_sMakeCString]
    $lPart GetName $pNameCStr
    set pName [DboTclHelper_sGetConstCharPtr $pNameCStr]
    if {$pName eq $partName} {
    puts "Updating part: $pName"
    # VALUE
    $lPart SetEffectivePropStringValue [DboTclHelper_sMakeCString "VALUE"] [DboTclHelper_sMakeCString $newValue]
    # PART_NUMBER
    $lPart SetEffectivePropStringValue [DboTclHelper_sMakeCString "PART_NUMBER"] [DboTclHelper_sMakeCString $newPartNumber]
    set partFound 1
    break
    if {!$partFound} {
    puts "ERROR: Part '$partName' not found"
    return
    # Update PACKAGE PCB Footprint
    set pkgIter [$lLib NewPackagesIter $lStatus]
    set lPackage [$pkgIter NextPackage $lStatus]
    set pkgFound 0
    while {$lPackage != $NullObj} {
    set pkgCStr [DboTclHelper_sMakeCString]
    $lPackage GetName $pkgCStr
    set pName [DboTclHelper_sGetConstCharPtr $pkgCStr]
    if {$pName eq $pkgName} {
    puts "Updating PCB Footprint for package: $pkgName"
    $lPackage SetPCBFootprint [DboTclHelper_sMakeCString $newPCBFootprint]
    set pkgFound 1
    break
    delete_DboLibPackagesIter $pkgIter
    if {!$pkgFound} {
    puts "ERROR: Package '$pkgName' not found"
    return
    puts "SUCCESS: Passive part updated"
    # example usage
    UpdatePassivePartAndPackage "test.olb" "CAP-1.Normal" "10uF" "HBH221" "CAP" "smdcap"
  • RT202604073158
    0 RT202604073158 7 months ago in reply to TechnoBobby
    So while going to use the function, I can get it to find the library but it is failing to find the part name I'm passing. I am using it as shown below.
    UpdatePassivePartAndPackage "path_to_file/RESISTORS.OLB" "5600452-000.Normal" "1" "NewPart" "5600452-000" "testfp"
    Any guesses as to what would cause this? Obviously the process is running and aborting at this point based on the fact that the error message is one that is defined in the process. When opening the library and looking in the "Part Properties" it seems obvious that this is the name of the part.
  • RT202604073158
    0 RT202604073158 7 months ago in reply to RT202604073158
    Sorry, what I had copied and pasted was the error message when I tested by removing a letter just to make sure that the error was coming from my script. The error message does also happen when everything is spelled correctly.
  • TechnoBobby
    0 TechnoBobby 7 months ago in reply to RT202604073158
    Hi RT202604073158 ,
    It appears you may be using an older capture version that relies on the legacy Symbol Editor. If you have access to a newer release, please try running the script there, as behavior may differ between versions.
    Additionally, you can verify the part names returned from:
    by adding a:
    puts $pName
    statement immediately after it. This will help confirm whether the expected value is being retrieved.
