  2. Allegro X Capture CIS
  3. issue while placing heterogenous part
  • State Verified Answer
  • Subscribers 50
  • Views 783
Shashank
Shashank 7 months ago
I have created a heterogeneous library having 2 packages and when trying to place before it used be like if i place section A and then it used to attach section B but now only the section is getting placed . Its not getting incremented after placing one
  • TechnoBobby
    TechnoBobby 7 months ago +1 verified
    Hi Shashank , Please check the setting under Options > Preferences > Miscellaneous and make sure Automatically reference placed parts is enabled in the Auto Reference section. Apply the change and try…
  • TechnoBobby
    +1 TechnoBobby 7 months ago
    Hi Shashank ,
    Please check the setting under Options > Preferences > Miscellaneous and make sure Automatically reference placed parts is enabled in the Auto Reference section. Apply the change and try placing the heterogeneous part again. Once this is enabled, placing section A should automatically advance to section B.
    Hope this helps!
  • Shashank
    0 Shashank 7 months ago in reply to TechnoBobby
    Hi TechnoBobby ,
    Its working.
    Thankyou for the solution.
