  2. Allegro X Capture CIS
  3. Default shortcut keys are not working
  • Subscribers 51
  • Views 1754
Siri
Siri 7 months ago
1. Close Capture if already Running.
2. Open and Edit in Notepad (or another text editor) the file located at C:Cadence/SPB_23.1/tools/bin/orCEFSettings.ini
3. Add following line in this file :
lang=en-US
4. Save the file.
5. Run Capture.
Also I have renamed cdssetup folder and the issue still persists.
Can anyone let me know what could be the reason.
  • TechnoBobby
    0 TechnoBobby 7 months ago
    Hi Siri ,
    Just to clarify, when you say the default shortcut keys are not working, do you mean common actions like Copy, Paste, or Delete? Do these actions work when you use the right‑click context menu or when accessing them through the Edit menu?
    Also, could you please confirm which hotfix of OrCAD Capture 23.1 you are currently using?
  • Siri
    0 Siri 6 months ago in reply to TechnoBobby
    Hello Bobby,
    Thank you for the reply
    Default shortcut keys like copy, paste, and cut are not working, though they function correctly when using the right-click context menu.
    Hotfix: S008
  • passedpawn
    0 passedpawn 4 months ago in reply to Siri
    I've had this exact thing happen many times.  I did report it to Cadence.  Restarting the software fixes temporarily.   I have not discovered the cause.
  • Zhifeng Jin
    0 Zhifeng Jin 2 months ago in reply to TechnoBobby
    Hello Bobby,
    This issue can also be frequently reproduced in the latest 25.1 HF005. For example, using Ctrl+C and Ctrl+V to copy‑paste schematic elements sometimes does not work. However, right‑clicking and selecting the Copy and Paste menu options functions correctly. I tried switching the input method, and the shortcut keys appeared to work again afterwards. Is there any progress from the official team?
  • Zhifeng Jin
    0 Zhifeng Jin 1 month ago in reply to Zhifeng Jin
    Please correct my previous observation to avoid misunderstanding. The issue is unrelated to switching input methods based on actual testing. When the problem occurs, simply clicking the mouse outside the software window restores normal operation.
