  2. Allegro X Capture CIS
  3. Seeing true Values in CIS explorer ,
  • Subscribers 50
  • Views 1042
Mhawley1
Mhawley1 5 months ago
I have a problem where in CIS explorer you put in a value a part and it finds parts based on characters and not the real value .
For example, if I type in 10uF in the value field it finds 10uF capacitors and also 110uF capacitors. Note the Compare field is = not contains . it still behaves the same way .
Has anyone else witnessed this and got around it ?
  • Jeet
    0 Jeet 5 months ago
    Can you share a snapshot of the query which you are running at your end?
    Also which version and hotfix of the tool you are using?
  • Mhawley1
    0 Mhawley1 5 months ago in reply to Jeet
    I will send a video . Also the version is Capture CIS 22.1 S11 ,I did notice it seems to be ok in CIS 25.1 Hotfix 30  .
  • Mhawley1
    Here is the video , takes a minute because the forum will vett it . https://youtu.be/oTRlONNjn_Q
  • Jeet
    0 Jeet 5 months ago in reply to Mhawley1
    Are you using the same database in V22.1 and in V25.1 ?
  • Mhawley1
    I am using the same DBC file and the same SQL server for the source Data .
