  2. Allegro X Capture CIS
  3. How does OrCAD Capture decide which net alias is used in...
  • Subscribers 50
  • Views 830
How does OrCAD Capture decide which net alias is used in the PCB netlist?
LogicNet
LogicNet 4 months ago
I have a schematic where a single net has multiple net aliases. For example, a power net is labeled as both VCC and +5V at different locations in the design. When creating the netlist for PCB, how does OrCAD Capture determine which net name is transferred to the PCB tool? Is there a way to explicitly control which alias is used in the generated netlist without removing the other net aliases?
Thanks.
  • Jeet
    0 Jeet 4 months ago
    PCB Netlist encounters multiple names for a single net, higher-priority aliases override lower priority aliases. Priority is determined by the source of the name, ranked as follows:
     Lowest:
    •      System-generated names
    •      Aliases
    •      Power object names
    •      Off-page connectors
    •      Hierarchical port names
     Highest:
    •      Named nets
     Any remaining conflicts among net names are resolved according to the following rules:
    • The net name closest to the "root" of the project takes precedence over those further away.
    • If the net is a bus, the net alias assigned to the greatest number of bus members has the highest priority.
    • Among net names of equal precedence, priority follows alphabetical order.
