  2. Allegro X Capture CIS
  3. Browsable CIS link always opens in Microsoft Edge
  • State Verified Answer
  • Subscribers 51
  • Views 709
LogicNet
LogicNet 3 months ago
Hi all,
I am using Capture CIS and have configured a property as Browsable, allowing users to click a link directly from CIS Explorer and open the associated document or webpage.
The functionality works as expected, but whenever I click the link, it always opens in Microsoft Edge. On my system, I would prefer these links to open in Google Chrome instead.
I checked the CIS configuration but could not find any setting that allows me to specify which browser should be used for browsable links.
Is it possible to configure CIS to launch browsable links using a specific browser such as Chrome?
Thanks!
  • TechnoBobby
    TechnoBobby 3 months ago +1 verified
    Hi LogicNet , The browser used for browsable links in CIS Explorer is controlled by Windows, not by a CIS-specific setting. As Ulf K mentioned, the first thing to check is Windows Default Apps. If Google…
  • Ulf K
    0 Ulf K 3 months ago
    If I am not wrong, the choise of browser setting is done in Windows system menus:
    System | Apps | Default Apps
  • TechnoBobby
    +1 TechnoBobby 3 months ago
    Hi LogicNet ,
    As Ulf K mentioned, the first thing to check is Windows Default Apps. If Google Chrome is configured as the default application for HTTP and HTTPS links, browsable links from CIS Explorer should open in Chrome rather than Microsoft Edge.
    If links continue to open in Edge even after changing the Windows default browser, then verify the registry association referenced in below article on ASK portal:
    Title: How to configure browsable links in OrCAD Capture CIS Explorer and set the default browser
    URL: https://ask.cadence.com/ASK/article-viewer?id=a1Od0000007MKbeEAG&pageName=article-viewer
    Hope this helps.
