  2. Allegro X Capture CIS
  3. Using Capture CIS 25.1 using ORCAD X professional plus and...
  • Subscribers 52
  • Views 726
Using Capture CIS 25.1 using ORCAD X professional plus and my license is active and cloud access is on, but I am told I am Offline and when trying to use parts from the library I get an error message.
CP202609102340
CP202609102340 22 days ago
I am having persistent trouble accessing the online/cloud features in OrCAD X Professional Plus, Capture CIS 25.1. This has been happening for approximately the last week or so. Capture reports that it is offline or not connected to the internet and displays error ORCAP-51017.
My computer has a working internet connection, but I cannot access the cloud component search and library resources I need for my work, including parts and footprints. This is currently interfering with my ability to work through my designs.
I use my own Cadence account, and my licenses are still available. Basic Capture functionality works: I tested opening a schematic, making a harmless edit, and saving it successfully.
So far, I have checked or tried the following:
            Checked Firewall and ensured everything that was required passed.
  • Confirmed that the cloud-on-startup option is enabled.
  • Confirmed that I have access to an active license
  • Tried accessing the service from different locations, but the problem persisted.
  • Checked Windows network configuration and confirmed that the connection uses Wi-Fi.
  • Successfully resolved www.cadence.com through DNS.
  • Successfully tested a TCP connection to www.cadence.com
  • Sent an HTTPS request to the Cadence website and received HTTP 302, redirecting to its homepage.
  • Checked WinHTTP proxy settings, which report direct access with no proxy.
  • Checked Windows user proxy settings, which show the proxy disabled.
  • Checked for CDS_LIC_FILE and LM_LICENSE_FILE in PowerShell; neither appeared in that session.
  • Searched Windows services by Cadence/FlexNet names; no matching services were returned.
  • Backed up my important work, uninstalled the software, and reinstalled it. The reinstall did not resolve the issue.
I would like to get the online functionality working again without repeatedly reinstalling the software or unnecessarily removing valid licensing information.
Thank you for your help.
  • CP202609102340
    CP202609102340 10 days ago in reply to maxx1234 +1
    It is still down on my end as well. Nothing seems to have changed yet.
  • maxx1234
    0 maxx1234 19 days ago
    I have been facing the same issue as well. Have you found a fix yet ?
  • CP202609102340
    0 CP202609102340 19 days ago in reply to maxx1234
    No unfortunately I have not. I believe it is a server side issue on Cadence's end as I seem to have exhausted all other measures. I have spoken with quite a few others as well who are having similar issues. Notably similar problems from other recent posts might indicate that within the week it will be remedied.
  • maxx1234
    0 maxx1234 11 days ago in reply to CP202609102340
    Has it been fixed yet ? I am still having the same issue.
  • TG202408061233
    0 TG202408061233 11 days ago in reply to maxx1234
    I can't access the cloud either and it was supposed to be fixed by now.  Seems like this would effect a lot of people and very strange that its been down for so long.
  • CP202609102340
    0 CP202609102340 10 days ago in reply to maxx1234
