  2. Allegro X Capture CIS
  3. How to turn off Internet databases (Samacsys, et al.)
  • State Verified Answer
  • Subscribers 50
  • Views 247
Ulf K
Ulf K 13 days ago
Forum Experts,
Is there a way to turn off/disable the Internet based component database options in Component Explorer (like Samacsys et al.) ?
I only use the built in CIS option with a local database which I maintain myself. My customers provides me with component info (schematics and footprints).
I get them either by mail or create them myself using the standards/rules that my customers have defined.
Have been looking where the capture.ini files and other reside but have found no configuration entries (that I dare experimenting with).
  • rg13
    rg13 5 days ago +2 verified
    You can find capture.ini at cdssetup\OrCAD_Capture\25.1.0 location. Also, if you dont want to use samacsys or any third party part search providers, then rather then using main menu Place > Component…
  • rg13
    +1 rg13 5 days ago
    Also, if you dont want to use samacsys or any third party part search providers, then rather then using main menu Place > Component, you can use RMB context menu on schematic canvas > Place Database Part or use shortcut key Z to directly open CIS explorer.
    • Vote Up +2 Vote Down
  • Ulf K
    0 Ulf K 1 day ago in reply to rg13
    In the past, I have been manually editing the capture.ini file several times. In my installation, the file is 800 lines with configuration data sometimes not that well organized. Anyway, I found only one config line that had the text "Ultra Librarian" in it (=no). No other lines with eg. Samacsys etc.
    It seems that there is no easy way to turn the internet providers off other than to use RMB to place a database part directly. That is good enough for me.
    Maybe Cadence could consider implementing a configuration switch added in a future hotfix.
