  2. Allegro X Capture CIS
  3. PDF Export Title Block issue
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 173
RC202609179615
RC202609179615 6 days ago
When trying to export my schematic design as a PDF, I'm having issues with the title block placement.
I have multiple sheets in my design and they vary in sheet size. The issue is that the very first sheet is the smallest and on that page the title block is correctly postioned in the bottom right corner but on the subsequent pages on the PDF, the title block is around the middle or on some larger sheets closer to the upper left hand corner.
What I'm noticing is that if I were to align the first page and place it on top of the other pages, aligned with the upper left hand corner, the title blocks are aligned. It's as though the title block postion was locked into the scaling of the first page and it put it there on all the rest of the pages.
I tried exporting the PDF with page output size different than default 0 but that didn't fix the issue.
Capture CIS 25.1 S050 (4459063) [7/18/2026]
  • TechnoBobby
    TechnoBobby 4 days ago +1 suggested
    Hi RC202609179615 , I checked this behavior in OrCAD Capture 25.1_S060 and was unable to reproduce the issue. The title block positions were correct across all pages in PDF, even with different sheet sizes…
  • TechnoBobby
    0 TechnoBobby 4 days ago
    Hi RC202609179615 ,
    I checked this behavior in OrCAD Capture 25.1_S060 and was unable to reproduce the issue. The title block positions were correct across all pages in PDF, even with different sheet sizes. I exported the PDF using the default page output size (0), and the placement was fine.
    Could you please try the following?
    a) Save the design after making any changes to the schematic page and title block placement.
    b) Try updating OrCAD Capture to the latest available hotfix and check if the issue persists.
    Please let us know the results.
  • RC202609179615
    0 RC202609179615 4 days ago in reply to TechnoBobby
    Hi TechnoBobby ,
    The update didn't fix it however, I was able to fix it by manually placing the title block and moving it.
    Thanks for the help.
