  2. Allegro X Capture CIS
  3. Understanding Autobackup and .DBK File Creation in OrCAD...
  • Subscribers 49
  • Views 33
Understanding Autobackup and .DBK File Creation in OrCAD X Capture CIS
Jeet
Jeet 16 hours ago
After configuring Options > Autobackup and defining the backup location and frequency, you may notice that the .DBK backup file is not created at every configured interval.
The Multi-level Backup mechanism creates a design backup only when the design has been modified and has not been manually saved during the specified backup interval.
For example, if the backup interval is set to 10 minutes, the .DBK file will be created only if:
  1. A change is made to the design.
  2. The design remains unsaved for 10 minutes.
If you manually save the design before the 10-minute interval expires, the backup will not be generated at that point.
Tip: To verify the behavior, modify the design and leave it unsaved for longer than the configured backup interval.
