  3. Updated LogoMaker code
  • Replies 19
  • Views 29104
DE202408202727
DE202408202727 over 18 years ago
Thanks to an idea from William, I have updated the code so that your distributed users can run the code without installing LFC. Just place another the variable (LFC_PATH) in their environment variables that points to the network installation. You will also need to move the contents of the network LEADCMD\Bin folder to the level up.
Cheers, Dave
logoMaker_public.zip
  • oldmouldy
    oldmouldy over 18 years ago
    This is an excellent utility, great work by Dave.
    I added a small change for my use which was to add an "OR" for the LFC_PATH so that the Allegro environment does not have to be changed to run.
  • Roger G
    Roger G over 17 years ago
    Dave
    Have just got this working at last away to get logos in properly.
  • C Shiva
    C Shiva over 17 years ago
     Dave,
     I have installed your skill file. Everything is Ok. But the output option is not enabled. So i can't create any logo's. Please help.
     Thanks in advance,
     Shiva.
  • DE202408202727
    DE202408202727 over 17 years ago
    Hi Shiva,
    Sorry for the late reply - I have been on leave.
     There are two reasons that the "Place  Logo" button could be not enabled.
    You must select an image file - the name will appear in the "Symbol Name" text area.
    The plugins must all be in place - potrace, mkbitmap and lfc
     Cheers, Dave
  • C Shiva
     Thanks Dave. Some times i couldn't load some image files whether it has same extension, and the loaded image has not converted to a logo. It faced some errors. And please confirm the path of potrace, mkbitmap and lfc file's in the screen shot. Please help. I'm new for skill.
    Shiva.
