  3. Updated LogoMaker code
  • Replies 19
  • Views 29111
DE202408202727
DE202408202727 over 18 years ago
Thanks to an idea from William, I have updated the code so that your distributed users can run the code without installing LFC. Just place another the variable (LFC_PATH) in their environment variables that points to the network installation. You will also need to move the contents of the network LEADCMD\Bin folder to the level up.
Cheers, Dave
logoMaker_public.zip
  • C Shiva
    C Shiva over 17 years ago
     The screenshot shows the error i have faced.
  • DE202408202727
    DE202408202727 over 17 years ago
    Hi Shiva (and others)
     It appears that I omitted to include the help file in my original zip file.
    It's attached here. Place it in your Skill folder. Hopefully it will help resolve your problems.
    Cheers, Dave
    • logoMakerHelp.txt
  • Bennigin
    Bennigin over 17 years ago
    I tried to get the code working and have the following error when I try to browse to the bitmap:
    W- *WARNING* (axlRunBatchDBProgram): Invalid option - ?noProgress
    When I select the bmp I get a "lfc bmp conversion failed" in the logomaker window.
    Any ideas?
  • DE202408202727
    Are you running 16.0 or above?
  • Bennigin
    No. I am running 15.2.
