  3. Updated LogoMaker code
  • Replies 19
  • Views 29118
DE202408202727
DE202408202727 over 18 years ago
Thanks to an idea from William, I have updated the code so that your distributed users can run the code without installing LFC. Just place another the variable (LFC_PATH) in their environment variables that points to the network installation. You will also need to move the contents of the network LEADCMD\Bin folder to the level up.
Cheers, Dave
logoMaker_public.zip
  • DE202408202727
    DE202408202727 over 17 years ago
    OK. It may work in 15.7 - I haven't tested it.
  • Bennigin
    Bennigin over 17 years ago
    Ah...
  • C Shiva
    C Shiva over 17 years ago
     Dave,
     Our's is  16.0. Sorry, i was so busy so couldn't read your help file.  Is it run in 16.0?
     Shiva.
  • EvanShultz
    EvanShultz over 17 years ago
    Hi Dave,
    Wow - this is a great utility! Fantastic work! Thank you!
    FYI, I also have to manually add the paths to both getShellEnvVar lines in logoMaker_public.il in order to get LogoMaker to work. I had everything installed a set up correctly, but it still didn't work until adding the direct path to those two folders.
