  3. How to get hole tolerance properties from padstack information...
  • Views 16086
How to get hole tolerance properties from padstack information and also change their value?
Bruenor
Bruenor over 18 years ago
Hi all,
I have learnt Skill language for about 1month. Because some accidental courses, I need to change a lot of padstacks' hole tolerance.
I tried using loadPadStack("padname") to get dbid of target padstack, but I couldn't found any properties about hole tolerance.
Can someone kindly help me solve this question?
 Thanks and Sincerely,
 Bruenor
  • kerchunk
    kerchunk over 15 years ago
    I too now have a need to do this ie. change alot of padstacks' hole tolerances.
    Searching thru the archives yields a few hits, saying you can't GET hole tolerance programmatically. Is this still true? Are there any "private" functions that can get the tolerance info?
    Searching thru the15.5 Skill Reference Guide on Sourcelink shows you can SET hole tolerance programmatically by using make_axlPadStackPad So it seems I'll need something along the lines of
    [pre]axlPurgePadstacks( 'padstacks nil)
    foreach( padstack_db axlDBGetDesign()->padstacks
        nname = padstack_db->name
        holeplating = axlDBGetDrillPlating( nname)
        drill_data = make_axlPadStackDrill(?drillDiameter padstack_db->drillDiameter,
                                               ?figure stringToSymbol( padstack_db->drillFigureName),
                                               ?figureSize 60:60,
                                               ?plating stringToSymbol( holeplating)
            pad_list = nil
            foreach( pad_db padstack_db->pads
                pad_list = cons( make_axlPadStackPad( ?layer pad_db->layer,
                                                      ?type  stringToSymbol( pad_db->type),
                                                      ?figure stringToSymbol( pad_db->figureName),
                                                      ?figureSize 80:80)
                                                  pad_list)
            );end-foreach
            ps_id = axlDBCreatePadStack( nname, drill_data, pad_list t)
    );end-foreach
    [/pre]]
    Anyone have a copy of something like this that works that they'd care to share?
     TIA,
    Chris Walters
    local Cadence guru
  • Nagaraj Shanmu
    Nagaraj Shanmu over 15 years ago
    Hi Chris
    I tried the skill docs but no clue how to get the tolerance value of drill.
    Did you find some method to do?
    I wish to extract the hole tolerance value for some validation.
    TIA,
    Nagaraj.
  • DE202408202727
    DE202408202727 over 15 years ago
    Hi guys,
    One way (maybe the only way) is to use extracta.
    These are fields I use in one utility that needs the tolerances:
    COMPOSITE_PAD
      DRILL_HOLE_NAME != ""
      PAD_STACK_NAME
      DRILL_HOLE_TYPE
      DRILL_HOLE_NAME
      DRILL_HOLE_NAME2
      DRILL_HOLE_NONSTANDARD
      DRILL_HOLE_PLATING
      DRILL_HOLE_POSTOL
      DRILL_HOLE_NEGTOL
      DRILL_HOLE_X
      DRILL_HOLE_Y
      DRILL_ARRAY_LOCATIONS
      START_LAYER_NAME
      END_LAYER_NAME
      START_LAYER_NUMBER
      END_LAYER_NUMBER
      DRILL_FIGURE_CHAR
      DRILL_FIGURE_SHAPE
      DRILL_FIGURE_WIDTH
      DRILL_FIGURE_HEIGHT
      DRILL_FIGURE_ROTATION
    Regards, Dave
  • Nagaraj Shanmu
    Thanks Dave,
    I also used the extracta already provided by Cadence @ <installation_path>share\pcb\text\views\pad_rep_view.txt
    And used infile to read and get the needed information about the padstack.
    Good day!!
    Nagaraj.
