  3. Hilight buried pads
  • Subscribers 163
  • Views 15575
Hilight buried pads
archive over 18 years ago
Hi
I need to hilight burried pads is there any skill codes or scripts or any other way?
Thanks and Regards,
Rajesh.
Originally posted in cdnusers.org by rajesh.
    A SKILL routine could likely be crafted to sniff these things out, yes.
    Describe how a pad is "buried".
    Chris Walters
    local Cadence guru
    Originally posted in cdnusers.org by kerchunk.
    Hi Chris Walters,
    Please find the burried padstack attached.
    Rajesh.
    buried_blind_pads.zip
    Hi Chris Walters,
    Did you find any solution for this! or any body else?
    Thanks and Regards,
    Rajesh
    If what you're asking for is a way to find/highlight all instances of a pad with a particular name,
    then these hints should get you pointed in the right direction.
    foreach( padstack_db axlDBGetDesign()->padstacks
    nname = padstack_db->name
    axlHighlightObject( padstack_db)
    and use axlDehighlightObject when you are done.
    HTH,
    Chris Walters
    local Cadence guru
