  3. Extract xsection and draw it
  • Replies 15
  • Subscribers 170
  • Views 25537
archive over 18 years ago
HI all,
I have used a skill program from that forum that extract layer etch and draw it to the design.
I have modified it to use the news api 16.x function.
I also extract thikness inter layer etc.
This is my first program so be gentle with me.
I attach it and let me know if i need to change something before send it to cadence to review it.
to use it, you just need to type XSection2 in your skill window.
regards
Jonathan
Originally posted in cdnusers.org by dumarjo.
Create_XSection_Figure.il
  • oldmouldy
    oldmouldy over 18 years ago
    Reposted as a ZIP..... same details as before.
    bobCXS2.zip
  • redwire
    redwire over 18 years ago
    Thanks all!  Nice job to those who helped make this.
    I *already* see some custom tweaks coming down the pike!  Stay tuned.
    Bill
  • vramanan
    vramanan over 18 years ago
     This is a wonderful script
     I have added some customization now
     Here are the following things that will be done
     1. Count the Layers ( will only work for even numbers)
    2.  Add the Dielectric Type(Name) inside the Dielectric Box (I left out Dk since it is variable)
    3. If the layer is signal then it will have split shapes
    (using Case statement instead of if and looking for the 2nd element inside the xsection data)
    4. Added tolerance to the total thickness
    I am attaching the materials.dat if you want to customize it (use as is)
    regards
    Venkata
    stack.zip
  • redwire
     Excellent work!  I like it.
    Bill
  • pakistan
    pakistan over 17 years ago
    Hi Venkata,
    I have allegro 16.0.
    I want to extract xsection for adding fab notes on pcb. I copied all files which you provide in zip file in my working directory.
    when I run the script the following msg occurs
    Script version: 16.01
    t
    Loading axlcore.cxt
    *Error* eval: undefined function - axlGetXSection
    plz let me know what should I do
    Thanks in advance
    Tanveer
