  3. Extract xsection and draw it
  • Replies 15
  • Subscribers 170
  • Views 25541
archive over 18 years ago
HI all,
I have used a skill program from that forum that extract layer etch and draw it to the design.
I have modified it to use the news api 16.x function.
I also extract thikness inter layer etc.
This is my first program so be gentle with me.
I attach it and let me know if i need to change something before send it to cadence to review it.
to use it, you just need to type XSection2 in your skill window.
regards
Jonathan
Originally posted in cdnusers.org by dumarjo.
Create_XSection_Figure.il
  • vramanan
    vramanan over 17 years ago
    You got have v16 or above to run this script
    Regards
    Venkata
  • RonScott
    RonScott over 15 years ago
    Venkata,
    I have been using your script with great success until I upgraded to 16.5. Now I get the following error message (see attachment). Any help will be appreciated.
    Cheers,
    Ron Scott
  • vramananx
    vramananx over 15 years ago
    Hi Ron looks like you are running the script file and the skill file is not found in the working directory you should include the path or load the skill file using allegro.ilinit so that xs is available all the time just put the stack.il in the working director or your skill directory then type skill load "stack.il" now just type xs
  • fxffxf
    fxffxf over 14 years ago
    With 16.5, look under the Manufacture menu and try the "Cross Section Chart" command.
  • Goblin60
    Goblin60 over 14 years ago
    Thanks, I tried the new chart and found I liked my script better. Found out what I was doing wrong and it works just fine.
    Cheers,
    Ron Scott CID+
