  3. how do you extract the holes dimension for oblong holes...
  • Views 16683
how do you extract the holes dimension for oblong holes in skill
Fred06
Fred06 over 18 years ago
In version 15.5.1 or 16.01 i think it's impossible to extract the correct dimension for the oblong holes in skill.
The value return after padstack->DrillDiameter is 1.0 for oblong with value slotx = 1.0 slotY = 2.0 in my padstacks.
for me it's a bug because the value returned it's not correct, Are you an idea ?
thank you !
  • DE202408202727
    DE202408202727 over 18 years ago
    There is an enhancement request in for this (CCR ID 587454). It should be available in 16.2
    As a work around I use the drillFigureWidth and drillFigureHeight attributes of the pin definition.
    Cheers, Dave
  • Fred06
    Thank You but i think it's not a good solution because we have a padstacks with circle holes and with oblong figure.
    I found an another solution .
    I use the export -v pad name.brd out.rpt, for export a file with old report format I read in skill this file and we have all information of the holes. ( slotx sloty or drill diameter , plated unplated etc...)
    Thanks you
  • Fred06
    This is the cadence solution. It's similar.
    It's an extract
    *Problem:
    I would like to extraxt the X and Y dimensions and the tolerance for my slot
    drills, what are the data fields used to extract this information?
    *Solution:
    The data fields for slot drills are:
    DRILL_HOLE_NAME slot major dimension
    DRILL_HOLE_NAME2 slot minor dimension
    DRILL_HOLE_POSTOL drill hole Positive tolerance
    DRILL_HOLE_NEGTOL drill hole Negative tolerance
    Save the text bellow as a file and you can use it in the Allegro report program
    to generate a report for slot drills:
    # ncdrill_slot.txt
    COMPOSITE_PAD
    # Slot hole types would have their major dimension in DRILL_HOLE_NAME
    # and their minor dimension in DRILL_HOLE_NAME2. CIRCLE_DRILL types
    # will simply have DRILL_HOLE_NAME2 set to the same value as in
    # DRILL_HOLE_NAME.
    # DRILL_FIGURE_ROTATION for slot holes will contain the rotation to be applied
    to the slot
    # hole, with the assumption of 0 degrees being the major dimension
    # of the slot hole along the X axis.
    DRILL_HOLE_TYPE = CIRCLE_DRILL
    OR
    DRILL_HOLE_TYPE = OVAL_SLOT
    OR
    DRILL_HOLE_TYPE = RECTANGLE_SLOT
    DRILL_HOLE_TYPE
    DRILL_HOLE_NAME
    DRILL_HOLE_NAME2
    DRILL_HOLE_PLATING
    DRILL_HOLE_POSTOL
    DRILL_HOLE_NEGTOL
    DRILL_HOLE_X
    DRILL_HOLE_Y
  • dgstan
    dgstan over 16 years ago
    Cheers, Dave
    So whatever became of this request? I don't see anything new in 16.2 (or 16.3 for that matter).
