  3. pls help me,about skill
  • Views 2232
steven_deng
steven_deng over 18 years ago
I want use a skill file query some net,only need some infomation,such as total items and net name,no other.
  • DE202408202727
    DE202408202727 over 18 years ago
    I'm not sure exactly what you want here.
    Typing "net ->??" will return all the attributes of a net. "net ->name" will return the name. Where "net" is the dbid of the net you are querying.
     Cheers, Dave
  • steven_deng
     Thank you.but my mean is the skill file like the "show element",but only need the listing and the net name or do my mean.ths!
  • fxffxf
    fxffxf over 18 years ago
     see the doc for the following skill APIS, axlShowObject and axlShowObjectToFile. Example code for axlShowObject is
    @ <Cdsroot>/share/pcb/examples/skill/select/ashselect.il
    Otherwise you can take a dbid and do:
      To see attributes it supports:  dbid->?
      To see values of those attributes:  dbid->??
  • steven_deng
     thanks a lot,I don't find the code file as your reply,I found the axlshowobject in cadence help file,but I'm not clear to write the skill for my mean,can you give me a Exm skill file?thank you very much!
