  3. Cadence suite for skill
  • Views 14786
MAAC
MAAC over 18 years ago
hi all,
does Allegro PCB Design CIS L 16.0 support for skill programming..... in my case i could start skill only after adding the performance option to it..
also i wanted to know whether to load the skill in env or in any other folder and where should i give the path to run the skill..
thanks.
  • urcuterock
    urcuterock over 18 years ago
      I think u can give the path in setup>User preferences>Config paths>script paths...
  • DE202408202727
    DE202408202727 over 18 years ago
    The L level license supports running Skill but not the interactive window.
    Place your Skill code in a folder labelled "skill" beneath the folder defined by your ALLEGRO_SITE variable.
    Cheers, Dave
