  3. Trying to extract all the data from a padstack
  • Subscribers 160
  • Views 13787
Carl Musetti
Carl Musetti over 17 years ago
All thanks in advance for any help at all on this?
I am rying to build an an external database such as an excel worksheet with all of the data element to a padstack suh as wheat you would see in the padstack editor form. I am having difficutly finding all the elements though. can anyone direct me to where in the manual it listing on all the datatypes in a padstack.
 I can easily get a list of pads by pinList=axlDBGetDesign->Padstacks but in parsing through that list I can seem to find hanles for all the data elements in the padstack for instance in the parameters tab in the padstack editor there is a field type that has 3 different types Throug, Blind/Buried, and Single. There is no handle for type but I can do car(pinList)->isThrough and it returns t or nil. thsi doesn't map into the 3 choices at all! I also can't find any handle what so ever for hole type, plating and tolerance
  • mcatramb91
    mcatramb91 over 17 years ago
    Hey Carl,
    I know you were looking for a SKILL solution but you can actually run a Padstack Definition Report (report -v pad) on the actually padstack in batch mode.
    report -v pad carl_padstack.pad carl_padstack_report.txt
    The default output file name is "pad_rep.txt" but you can specify the output file name as indicated above "carl_padstack_report.txt". This report will contains all the information inside of the padstack in sort of a csv format which can be imported into Excel.
    Hope this helps,
    Michael Catrambone
    UTStarcom, Inc
  • kerchunk
    kerchunk over 17 years ago
     Hey Carl,
    I've sent something to you directly at cmu***@infin*****.com  . If you don't receive it shortly email me at kerchunk@*****.com and I'll resend it.
    Chris Walters
    local Cadence guru
  • Rajesh Bangari
    Rajesh Bangari over 11 years ago
    Thanks in Advance
    I want to extract an data in the below mentioned format
    Padstack name - FILMMASKTOP - Width - Height
    In a table format (Notepad or Excel)
    This all infomation is already available in the Padstack defination report but formating the data to the above mentioned format is bit difficult.
