  3. Automatic Film Creation
  • Views 16627
vramanan
vramanan over 18 years ago
 Hi
This is a quick skill file I put together to make the life of designers little easier
Requirement: Create the Film definitions  quickly and make the films to consider plane and etch
 Now this will only do the etch layers
I am still working on the thought process how to customize the other layers like silk/paste/ mask/assembly and fab
But for now you can edit this to suite your needs
Please wait for further new revisions
regards
Venkata
cf.il
  • Cadpro2K
    Cadpro2K over 18 years ago
    Easy, but it will take some time.
    Make a series of "starter" boards with differing layers, and the FILM layers set. It's pretty easy. I do something like that because I almost always start from a prior board design. I simple import the new data, and go from there.
    You could start with a 4 layer boards, and all the film layers, then go 6 layer, 8 layer, etc. etc. Once you know the differing technologies your company designs to, you can generate more "starter" boards with differing layer stacks.
    Good day.
    Mitch
  • mcatramb91
    mcatramb91 over 18 years ago
    Can you add your SKILL file to a ZIP file then attach it to this thread.  An ongoing problem with the forums is the attachment of SKILL files where it may appear to be attached but when someone tries to download the attachment it is not found.  Adding it to a ZIP file and reattaching to the thread normally does the trick.
     Interested to see what you have come up with.
    Michael Catrambone
    UTStarcom, Inc
  • vramanan
     Hi Michael
    Using axlDBGetLayerType and axlSubclasses("ETCH")
    Using a for loop for "length of axlSubclasses" I create the axlDBCreateFilmRec by turning ON respective layers with axlVisibleLayer
    We always face problems with documentation tell me about it :-)
    I amjust using the layer name as film name
    I was  looking at your paper on automating artwork film record it is impressive
    I was thinking in the similar lines to implement it purely in skill
    This are my thoughts
    1. A input form inside allegro to input different part number(assy/fab) and revs
    2.  Create Film Title block and FAB/Assy title block
    another thought was why don't I create a global parameter for Date/part#'s and Update it through interactive forms
    I always forget to change thre revs
    regards
    Venkata
    cf.zip
