  3. Check for lowest value and make a list
  • Replies 7
  • Subscribers 166
  • Views 17725
Javinder
Javinder over 18 years ago
My problem is that I have a long list of lists that I would pick out the some of the lists depending of some criteria.
Example: I would like to pick out the lowest value in the 2th coulumn for each value in the first column.
(("BOTTOM" 650)
    ("BOTTOM" 650)
    ("BOTTOM" 650)
    ("BOTTOM" 750)
    ("BOTTOM" 650)
    ("BOTTOM" 450)
    ("BOTTOM" 650)
    ("BOTTOM" 650)
    ("TOP" 500)
    ("TOP" 500)
    ("TOP" 450)
    ("TOP" 350)
    ("TOP" 500)
    ("TOP" 500)
    ("TOP" 500) )
 Can any one give me some example code snippets
  • Anton
    Anton over 18 years ago
    You can try something like:
    prog((longList min items)
    longList=_your_long_list_of_lists_
    min=nil items=nil
    foreach(i longList unless(member(car(i) items) items=cons(car(i) items)))
    foreach(i items min=cons(car(sort(setof(r longList car(r)==i) lambda((a b) greaterp(cadr(b) cadr(a))))) min))
    return(min))
  • redwire
    redwire over 18 years ago
     Are you a recent winner of the obfuscated code contest? :) Sorry, I couldn't resist. I do C but SKILL is ...well...wow!
  • DE202408202727
    DE202408202727 over 18 years ago
    While there are prizes for obfuscated code:
    mapcar(lambda((layer), assoc(layer, sort(copy(myList), lambda((a b) cadr(a) < cadr(b))) )), unique(mapcar('car, myList)))
  • pcbgeorge
    pcbgeorge over 18 years ago
    Don't think of it as C.  That is bound to cause "Wows".  Think of it as Lisp, a language that was originally designed to minimize variables.
    Think of Anton's prog in all it's "functional language" glory, as it's supposed to be written...
    (prog (longList min items) (setq min nil) (setq items nil) (setq longList _your_long_list_of_lists_) (foreach i longList (unless (member (car i) items) (setq items (cons (car i) items)))) (foreach i items (setq min (cons (car (sort (setof r longList (equal (car r) i)) (lambda (a b) (greaterp (cadr b) (cadr a))))) min))) (return min))
    Heck, if you have a development license you can turn any of your code into this using the "compress "statement.  Down with imperative languages and messing around with functional languages so they can "look" imperative <|:)
  • redwire
     Ok....I am wiping the gray matter off the screen.  A big splat just hit. What the HECK does that code do??? :)
    Is it equivalent to the following?  (note: not mine, one entry from "hoyle" who ever you are)
    char*O=" <60>!?\\\n"_ doubIe[010]_ int0,int1 _ Iong=0 _ inIine(int eIse){int
    O1O=!O _ l=!O;for(;O1O<010;++O1O)l+=(O1O[doubIe]*pow(eIse,O1O));return l;}int
    main(int booI,char*eIse[){int I=1,x=-*O;if(eIse){for(;I<010+1;I++)I[doubIe-1]
    =booI>I?atof(I[eIse]):!O switch(*O)x++)abs(inIine(x))>Iong&&(Iong=abs(inIine(x
    )));int1=Iong;main(-*O>>1,0);}else{if(booI<*O>>1){int0=int1;int1=int0-2*Iong/0
    [O]switch(5[O]))putchar(x-*O?(int0>=inIine(x)&&do(1,x)do(0,true)do(0,false)
    case(2,1)do(1,true)do(0,false)6[O]case(-3,6)do(0,false)6[O]-3[O]:do(1,false)
    case(5,4)x?booI?0:6[O]:7[O])+*O:8[O]),x++;main(++booI,0);}}}
