  3. Starting an External Program
  • Views 15584
wERerABbiT
wERerABbiT over 18 years ago
Hi All,
Is there a Skill command to start an external program?
For example can I open a text file using notepad using a skill command?
Thanks All
  • wERerABbiT
    Hi All,
    Wordpad can be started with --> axlUIEditFile(BOMListFile "BOM List" nil)
    but what about other programs?
    Also, is it possible to use a Skill code in PCB Editor to run some functions in Allegro CIS?
    Let say to generate a BOM in Allegro Capture.
    Thanks All
  • DE202408202727
    DE202408202727 over 18 years ago
    You can use the system or shell commands. I often use axlRunBatchDBProgram:
    axlRunBatchDBProgram("myCmdName", "myCmd.exe", ?noUnload t, ?silent t, ?noProgress t)
  • Ejlersen
    Ejlersen over 18 years ago
    You'll not be able to use skill program inside Capture CIS but you should be able to create some very neat reports using Seagate Crystal Reports for templating.
