  3. Using SKILL to process external Database file
  • Views 14567
alberthyc
alberthyc over 18 years ago
Hi, i'm currently working on a project that tries utilize an external DRC database file of a design projectfrom some other software, grab the information in that DB file and put the DRC markers on the APD on the same design project. I think there are two ways to do it, either use SKILL to process the strings in DB file directly or use Perl to process the DB file, put the grouped data in excel file and use SKILL script to import the EXCEL file. So my question is, which method is better? and If i choose to use Perl to process the DB file, how do i use SKILL the read the EXCEL file?
  • Austin CAD Guy
    Austin CAD Guy over 18 years ago
     Either way, you are reading a database in SKILL, ASCII or Excell. SKILL can process this using scanf or fscanf but perl is a better ASCII processor. You can use the perl command to analyze the output and write a file full of SKILL commands which call dbCreateMarker to create the appropriate markers.Load this file into Virtuoso and it will create marker segments which can then be used with the annotation browser (IC6.1) or the marker finder (IC5.1.41).
    Ted
