  3. How to determine if any objects exist on subclass
  • Views 14864
Ejlersen
Ejlersen over 17 years ago
Does anyone know how you can determine if any objects exist on subclass "Manufacturing/NCLEGEND-1-4" on a 4 layer PCB?
Does anyone know how to get the size of the drill legend before placing it?
Best regards,
Ole
  • kerchunk
    kerchunk over 17 years ago
    I dug up a snippet that looks close to what you need - give this a whirl --
    procedure( helpOle()
    let(( mfg_layer_list nclegend_list obj_list)
    oldview = axlVisibleGet() ;store what you see
    mfg_layer_list = axlGetParam("paramLayerGroup:MANUFACTURING")->groupMembers
    nclegend_list = setof( xx mfg_layer_list ( substring( xx 1 8) == "NCLEGEND"))
    foreach( layyer nclegend_list
        classname = strcat( "MANUFACTURING/" layyer)
        newview = axlVisibleSet( classname)
        axlSetFindFilter(?onButtons list("ALL") ?enabled list("ALL"))
        obj_list = cons( axlGetSelSet( axlAddSelectAll()) obj_list)
    );end-foreach
    axlVisibleSet( oldview) ;restore
    printf("found %n objects on the MFG/NCLEGEND subclasses\n", length( obj_list))
    );end-let
    );end-procedure
    HTH,
    Chris Walters
    local Cadence guru
  • Ejlersen
    Hi Chris,
    Thanks a lot for this, I'll test it out.
    br,
    Ole
