  3. running a batch command like pkzip inside Skill
  • Views 16503
Ejlersen
Ejlersen over 17 years ago
I'm looking for a method to be able to run a batch command inside skill. I'm not talking about running an Allegro batch command, but thirdparty batch commands.
Does anyone know if this is doable?
Best regards,
Ole
  • Ejlersen
    Hi All,
    No need to worry. I found the solution
    I can use axlShell to run a shell command e.g., axlShell( "shell pkzip zipfile.zip *.art")
    Best regards,
    Ole
  • kumarsanj
    kumarsanj over 7 years ago in reply to Ejlersen
    Hi Ole,
    Could you please share the code, I was willing to zipp the files using "7-ZIP".
    Sanjeev
  • Ejlersen
    Ejlersen over 7 years ago in reply to kumarsanj
    Hi Sanjeev
    I can share the zipping part of my code, but it has changed and I'm using another method now.
    destination = axlOSSlash(strcat(getWorkingDir() "/" outdir "/" project_name ".zip"))
    source = axlOSSlash(strcat(getWorkingDir() "/" outdir))
    sprintf(cmddata "cmd /c cdszip -q -j -r \"%s\" \"%s/*.*\" -x \"%s/*.*\"" destination source source)
    axlRunBatchDBProgram("Zip data" cmddata ?noUnload t ?silent t ?noProgress t)
    where outdir is a subdirectory name below the board directory and project_name is the board design name.
    I hope this helps
    Ole
  • kumarsanj
    Thank You Ole for providing the code and details. Yeah certainly it will help me.
    Sanjeev
