  3. What different between PCB Editor15.5 and PCB Editor16....
  • Views 14713
What different between PCB Editor15.5 and PCB Editor16.0
ELEKVN
ELEKVN over 17 years ago
 Hi all, I have some skills can use for PCB Editor15.5, but cannot use for PCB Editor16.0.
I don't known What different between them. Can you hep me.
Tks.
Luan
  • oldmouldy
    oldmouldy over 17 years ago
    You mean "Skill routines that no longer work"?
    Check the documentation at <install_dir>/share/pcb/examples/skill/DOC, the <version>.txt list the routines in each version, the "Changes<version>to<version>.txt" list the changed routines, see if you are using any of the changed routines. Also the skill capabilities have some associated licensing, some routines will not work in lower product options.
  • ELEKVN
     Thank you. I will try
