  3. axlDBcreateRectangle
  • Replies 9
  • Views 17921
malih
malih over 17 years ago
Hi
How assign layer to which to add the rectangle and width of the rectangle in axlDBcreateRectangle function?
please help me
thanks
  • fxffxf
    fxffxf over 17 years ago
     In the Allegro Skill Doc for  axlDBcreateRectangle see the 3rd example  to create a rectangle on a specific layer. The 1st two examples will create a rectangle on the current active layer (axlGetActiveLayer / axlSetActiveLayer).
    Allegro only supports filled and unfilled rectangles. We do not support rectangles  with awidth. You would need to use axlDBCreateLine to create a line @ width.
  • malih
    many thanks fxffxf, Is there any way to assign rules, in SKILL?
  • fxffxf
     by rules do you mean DRC rules?
  • malih
    hi yes
    Is there any way to define DRC rules, in SKILL? for example defining spacing or phyzical constraint
  • DE202408202727
    DE202408202727 over 17 years ago
    Take a look at the axlCNS... commands. Specifically axlCNSCreate.
     Dave
