  3. Can we edit file export placement?
  • Views 16375
ELEKVN
ELEKVN over 17 years ago
 Dear all,
In Allegro PCB, when we want to export placement,
we can chose File/Export/placement.
Can we edit it, where is it?
Elek
  • Cadpro2K
    Cadpro2K over 17 years ago
    It's a simple ascii text file. You can certainly modify it. Be careful with the syntax.
    It's located in the folder you're modifying the board file in. Should be called something like PLACE_TXT.txt or something.
    Good day.
    Mitch
  • ELEKVN
     Thank Mitch,
    Yes, I known file "PLACE_TXT.txt". ButI want to ask Allegro PCB use skill to make this file?
    And Can we edit this skill?
    Bacause some components  have rotations do not fix with rule of my company,
    so I want change this skill to have file  "PLACE_TXT.txt" has true ratation.
    Tks
    Elek
  • oldmouldy
    oldmouldy over 17 years ago
    Even if this function were to use skill within the product, the code belongs to Cadence and it would be unlikely that you would be provided with it - chances are that the routine is actually implemented in compiled code though.
    To get an idea of how to do this with skill, it might be best to look at an existing published skill function which dumps part properties and modify this to process the data to meet your specific requirements.
  • Ejlersen
    Ejlersen over 17 years ago
    I would recommend that you look at post /forums/T/11420.aspx
    Best regards,
    Ole
