  3. How to remove new line character (\n) in a string
  • Views 21913
skillnewbie
skillnewbie over 17 years ago
hi,
 I use gets funstion to scan line by line of a text file and obtain the text with "\n"
at the end of it. I want to remove the "\n" at the end of the string, is there a skill function
 to do this? Just like chomp in perl...
 if i am to use rexCompile and rexReplace, how to ensure the last "\n" is to be replaced?
  • Ejlersen
    Ejlersen over 17 years ago
    If you know the string contains \n then you could use substring combined with substring
    line = "This is a test line\n"
    line = substring(line 1 strlen(line)-1)
    You could probably use nindex to figure out if the string contains \n
    Best regards,
    Ole
  • aplumb
    aplumb over 17 years ago
     I'm more familiar with the IC side of things, but try the following:
    myString="some\nstring\n"
    printf(myString)
    while(rexMatchp("\\([^\n]*\\)\n\\([^\n]*\\)" myString) myString=rexSubstitute("\\1 \\2") )
    printf(myString)
  • Ejlersen
     To my knowledge, both would work fine. Dont know which is the most efficient.
    br,
    Ole
  • skillnewbie
    hi ejlersen and aplump,
    thanks for your help. ejlersen's solution works fine with me.
    but the RE portion in aplump's coding looks quite difficult to me for the time being...
    thanks for the effort anyway
    newbie
  • skillnewbie
    hi, just another question related to RE,
    rexMatchp("..."  ...) means matching with REs, how about not matching?
    i tried to add ! in or before the " ", but it does NOT work...
