  3. Form checklist question
  • Views 16277
Ejlersen
Ejlersen over 17 years ago
I was wondering if anyone know if it is necessary to check each setting on a checklist?
I have a long list of checks like the ones shown below. I could use axlFormGetField( _ns_pdf_outform  "300_dpi") to get status for just that one field. I'm more interested in just getting the one that is set, are there any functionality for that?
FIELD 300_dpi
FLOC 6 4
CHECKLIST "300 dpi" "dpi"
ENDFIELD
FIELD 600_dpi
FLOC 6 6
CHECKLIST "600 dpi" "dpi"
ENDFIELD
Best regards,
Ole
  • aCraig
    aCraig over 17 years ago
    Ole,
    I don't beleive that functionality exists. Typically I would keep track of which radial button has been selected in the callback function defined when the form is created.
    defun(myCallBack (_ns_pdf_outform)
    case(_ns_pdf_outform
      (300_dpi
        Global->300_dpi = t
        Global->600_dpi = nil
  • fxffxf
    fxffxf over 17 years ago
     It would not be difficult to write a skill function to do this. The form handle has an attribute that lists all of the fields in the form. You can use axlFormGetFieldType to query the field type. It is then a simple process of iterating on all of the fields. Any that are of type CHECKITEM are a checkbox field, you would then query on its current setting - axlFormGetField. Add any that are set to a return list of checkbox field names.
                 fw = axlFormCreate( ... )
                 fw->fields    ; get list of all fields inform
  • Ejlersen
    Thanks for your answers.I was just a bit surprised such a function not existe, since all checkitems in the same group have a common radiolabel.
     best regards,
    Ole
  • wilef
    wilef over 8 years ago in reply to fxffxf
    This wouldn't really work if you had more than one checklist group. I don't see a way to grab the group a field is associated with in SKILL. Less elegant method would be writing a function that passes in a list of the fields you want to check (you already have to know which ones are in the group you want). and iterate through them that way.
