  3. Change text block size, Allegro script and skill
  • Replies 17
  • Subscribers 169
  • Views 31686
skillnewbie
skillnewbie over 17 years ago
hi,
I want to change a text block size (#16). i run a script recording and get this from the *.scr
 setwindow pcb
trapsize 302
define text
setwindow form.textblock
FORM textblock 16 width 0.1000
FORM textblock 16 height 0.1000
FORM textblock 16 line_spacing 0.0200
FORM textblock 16 photoplot_width 0.0100
FORM textblock done
setwindow pcb
just wonder what the FORM means in a script file...it is not a valid command in Allegro
 is it possible to enclose the FORM statements in skill code?
  • fxffxf
    fxffxf over 17 years ago
     Either call the script from skill or combine all the statements on a single line and call that line from skill
    axlShell(" define text; setwindow form.textblock; FORM textblock 16 width 0.1000; <...>;  FORM textblock done")
       the ; allows commands to be chained on a single line and the <...> is the rest of your script.
  • Boardman
    Boardman over 17 years ago
    If you still need some additional help with this, I have included a piece of skill code I wrote to check and change some Text block data for my job. Take a look, maybe you can modify it for your needs.
     ; vc_SetTxtPlotW.il
    ; Ver. 1.1- 11-25-2008 - VC
    ; Written by:
    ;      Vincent Canulli Sr.
    ;  boardman0@lycos.com
    ; This will set all fields of the first four text blocks for you and then check to see that all the remaining
    ; text blocks have the PhotoPlot Width set to our standards. If it is not it will correct it.
    axlCmdRegister( "settxtpw" 'vc_SetTextPlotW )   ;register the command with allegro
    ;Globals
    defun( vc_SetTextPlotW ()
      let(( x p txtBlk_name txtBlk_photo txtBlk_height )
      axlMsgPut( " Running vc_SetTxtPlotW" )
      axlUIWPrint( nil " Check the allegro journal file for Text Block PhotoPlot Width changes if interested." )
       for(i, 1, axlDBControl('maxTextBlock)    ; loop from 1 to max text block number
      sprintf(p, "paramTextBlock:%d", i)    ; set p equal to the dbid of the text block number
      txtBlk_name = axlGetParam(p)->name     ; get the name field
      txtBlk_photo = axlGetParam(p)->photoWidth  ; get the photoWidth field
      txtBlk_height = axlGetParam(p)->height   ; get the height filed
       ; test each case and correct if needed
       cond(
        ( equal( txtBlk_name "1" ) x=axlGetParam(p) x->width=0.2540 x->height=0.3810 x->lineSpace=0.5080 x->photoWidth=0 x->charSpace=0.0762 axlSetParam(x) )
        ( equal( txtBlk_name "2" ) x=axlGetParam(p) x->width=0.5842 x->height=0.7874 x->lineSpace=0.9906 x->photoWidth=0.1270 x->charSpace=0.1524 axlSetParam(x) )
        ( equal( txtBlk_name "3" ) x=axlGetParam(p) x->width=0.9652 x->height=1.2700 x->lineSpace=1.6002 x->photoWidth=0.1524 x->charSpace=0.2032 axlSetParam(x) )
        ( equal( txtBlk_name "4" ) x=axlGetParam(p) x->width=0.6096 x->height=1.0160 x->lineSpace=2.0066 x->photoWidth=0.1524 x->charSpace=0.1524 axlSetParam(x) )
        ( txtBlk_height <=0
         axlMsgPut( "*** Warning Text Block - #%d has an invalid height! ***" i );
         axlUIConfirm( sprintf( nil "*** Warning Text Block - #%d has an invalid height! ***" i ))
        ( txtBlk_height <2.540 && atoi( txtBlk_name ) >4 && nequal( txtBlk_photo 0.1524) x=axlGetParam(p) x->photoWidth=0.1524 axlSetParam(x)
         axlMsgPut( " Text Block %s PhotoPlot Width was changed from %n to 0.1524." txtBlk_name txtBlk_photo ))
        ( txtBlk_height <3.810 && txtBlk_height >=2.540 && atoi( txtBlk_name ) >4 && nequal( txtBlk_photo 0.2540 ) x=axlGetParam(p) x->photoWidth=0.2540 axlSetParam(x)
         axlMsgPut( " Text Block %s PhotoPlot Width was changed from %n to 0.2540." txtBlk_name txtBlk_photo ))
        ( txtBlk_height <5.080 && txtBlk_height >=3.810 && atoi( txtBlk_name ) >4 && nequal( txtBlk_photo 0.3810 ) x=axlGetParam(p) x->photoWidth=0.3810 axlSetParam(x)
         axlMsgPut( " Text Block %s PhotoPlot Width was changed from %n to 0.3810." txtBlk_name txtBlk_photo ))
        ( txtBlk_height <6.350 && txtBlk_height >=5.080 && atoi( txtBlk_name ) >4 && nequal( txtBlk_photo 0.5080 ) x=axlGetParam(p) x->photoWidth=0.5080 axlSetParam(x)
         axlMsgPut( " Text Block %s PhotoPlot Width was changed from %n to 0.5080." txtBlk_name txtBlk_photo ))
        ( txtBlk_height >=6.350 && atoi( txtBlk_name ) >4 && nequal( txtBlk_photo 0.6350 ) x=axlGetParam(p) x->photoWidth=0.6350 axlSetParam(x)
         axlMsgPut( " Text Block %s PhotoPlot Width was changed from %n to 0.6350." txtBlk_name txtBlk_photo ))
       );end cond
      );end for
      axlMsgPut( " Text PhotoPlot Widths have been checked and/or corrected." )
     );end let
    );end vc_SetTextPlotW
  • skillnewbie
    Hi Vincent and fxffxf,
    Vincent's code might be a little difficult for me to understand in details,
    anyway, thanks for sharing with me the helpful info =)
  • vramanan
    vramanan over 16 years ago
     Hi I hope this helps
    p=axlGetParam("paramTextBlock:16")
    p->width=100
    p->height=75
    p->photoWidth=18
    p->charSpace=25
    p->lineSpace=20
    axlSetParam(p)
    regards
    Venkata
  • Boardman
    Boardman over 16 years ago
    Hi Venkata,
    I solved the problem right after making the post to the forum.
    I guess I forgot to go back and remove the post.
    What I really wanted was to check the 1st 4 text blocks and set them if they were not what I expected.
    Then I wanted to make sure all the photoplot widths had a value.
    Here is what I used in case someone else would want it.
    ; vc_SetTxtPlotW.il
    ; Written by:
    ; text blocks have the PhotoPlot Width set to IXIA standards. If it is not it will correct it.
    ;Globals
                                        cond(
                                                    ( txtBlk_height <=0
                                        );end cond
                            );end for
                );end let
    Thank you,
    Vince
    Vincent Canulli Sr.
    Principal CAD Engineer I
