  3. Extract NC drill and NC route filenames
  • Views 15473
bulldog
bulldog over 17 years ago
I was wondering if there is a way to extract the NC drill and NC route filenames using Skill?
  • Ejlersen
    Ejlersen over 17 years ago
    To my knowledge there is no such function.
    You should however be able to extract all the subclass names in class Manufacturing.
    Then check if there's any named "nclegend-x-y" where x is start layer and y is end layer (e.g. nclengen-1-4) using nindex.
    After drill generation you need to check for drill files named nclegend-x-y.drl nclegend-x-y-np.drl (nonplated) using isFile and the ads_sdart path. Otherwise you would have to check padstacks for plating status to figure out the file names that will be generated.
    Best regards,
    Ole
  • bulldog
    Thanks Ole,
    I'm a little disappointed that there isn't a function in Skill to extract what I need but you've given me ideas on how to get the job done.
    Best regards,
    Bulldog
  • ELEKVN
    ELEKVN over 17 years ago
    Best regards,
    Ole
    That is good  idea
    Elek
  • redwire
    redwire over 17 years ago
     Recall that these are stored in a parameter text file and can be easily parsed by SKILL to get the last known setting.  Or, you could force the names by shelling a script...lots of ways to skin this cat.
