  3. Adding class/subclass to artwork films
  • Views 2215
bulldog
bulldog over 17 years ago
Hi all,
I have a snippet from film_reorder.il that I would like to modify.  I would like to check the film_layers list for the DRAWING FORMAT/TITLE_BLOCK class/subclass and add it if it is not present.  Can anyone point me in the right direction on how to do this?  The snippet follows:
(defun get_film_list ()
prog( (dbid_film test_film _film _active_films tfilm)
defstruct(filmrecord film_name film_layers pad_aperture fullcontact mirror negative rotation
shapefill unconnect_pads aperture_rotation vector)
(setq i 0)
dbid_film = axlGetParam("artwork")
foreach(filmgp dbid_film->groupMembers
test_film = strcat("artwork:" filmgp)
_film = axlGetParam(test_film)
film_array[i] = make_filmrecord(
?film_name _film->name
?film_layers list(_film->groupMembers)
?pad_aperture _film->drawMissingPadApertures
?fullcontact _film->fullContact
?mirror _film->mirrored
?negative _film->negative
?rotation _film->rotation
?shapefill _film->suppressShapeFill
?unconnect_pads _film->suppressUnconnectPads
?aperture_rotation _film->useApertureRotation
?vector _film->vectorBasedPad
; Modify the structures to have 0 or 1 so as to pass argument during film creation.
if(film_array[i]->pad_aperture == t then film_array[i]->pad_aperture=1 else film_array[i]->pad_aperture=0)
if(film_array[i]->fullcontact == t then film_array[i]->fullcontact=1 else film_array[i]->fullcontact=0)
if(film_array[i]->mirror == t then film_array[i]->mirror=1 else film_array[i]->mirror=0)
if(film_array[i]->negative == t then film_array[i]->negative=0 else film_array[i]->negative=1)
if(film_array[i]->shapefill == t then film_array[i]->shapefill=0 else film_array[i]->shapefill=1)
if(film_array[i]->vector == t then film_array[i]->vector=1 else film_array[i]->vector=0)
if(film_array[i]->unconnect_pads == t then film_array[i]->unconnect_pads=1
else film_array[i]->unconnect_pads=0)
if(film_array[i]->aperture_rotation == t then film_array[i]->aperture_rotation=1
else film_array[i]->aperture_rotation=0)
case(film_array[i]->rotation
(0 film_array[i]->rotation=0)
(90 film_array[i]->rotation=2)
(180 film_array[i]->rotation=4)
(270 film_array[i]->rotation=6)
) ; end case
i++
) ; end foreach
return(i)
) ; end prog
);end defun
  • DE202408202727
    DE202408202727 over 17 years ago
    Try replacing _film = axlGetParam(test_film) with the following lines:
      unless(member("DRAWING FORMAT/TITLE_BLOCK", _film ->groupMembers)
        _film ->groupMembers = cons("DRAWING FORMAT/TITLE_BLOCK", _film ->groupMembers)
    Dave
  • bulldog
    Thanks Dave, that is exactly what I was looking for.
    Bulldog
