  3. How to run allegro procedure commands within SKILLshell...
  • Views 16502
How to run allegro procedure commands within SKILLshell?
vramanan
vramanan over 17 years ago
Hi Guys
I am stuck on a issue and I don't know if it is possible to do
I am trying to run some allegro commands like
"setwindow pcb" or FORM mini subclass AUTOSILK_TOP or pick 9740.755 11678.853
inside the skill shell
The intention is to pass the x,y on to the pick command
so here is what I want to achieve
POintx = 111
Pointy = 111
now I want to run/invoke pick PointX Pointy from inside the shell
How do I do that?
any help is greatly appreciated
regards Venkata
  • Ejlersen
    Ejlersen over 17 years ago
    I would recommend that you read the post /forums/T/11598.aspx
    commands must be separated by semicolon for your commands.
    Best regards,
    Ole
  • vramanan
     Hi Ole
    Thanks for pointing out the thread, I did go over it, but I still have trouble
     Can you give me an example for the following scenario?
     I want to run the following allegro command
    setwindow pcb
     I tried the following
    axlRunBatchDBProgram("test" "setwindow pcb")
    but it didn't work
    regards
  • EvanShultz
    EvanShultz over 17 years ago
     Hi Venkata,
    This is easy. I don't see the answer in the linked thread, but Ole gave you the answer - use semicolons. So the command should be:
     axlShell("test; setwindow pcb")
    Also see axlShell.txt at %CDSROOT%\share\pcb\examples\skill\DOC\FUNCS. That gives you another example.
