  3. Error when void shape?????????
  • Replies 9
  • Views 20788
ELEKVN
ELEKVN over 17 years ago
   I want to creat one shape and void it.
  I could creat shape by blow code
        mypath = axlPathStart( list(-3200.000:5812.000))
        mypath = axlPathLine( mypath, 0.0, -3200.000:5020.000)
        mypath = axlPathLine( mypath, 0.0, -4016.000:5020.000)
        mypath = axlPathLine( mypath, 0.0, -4016.000:5812.000)
        mypath = axlPathLine( mypath, 0.0, -3200.000:5812.000)
        myshape = axlDBCreateOpenShape( mypath, t,"etch/top", "GND")
        axlDBCreateCloseShape( myshape)
 But I could't void this shape by below code:
        axlSetFindFilter(?enabled (list "noall" "Shapes" "Voids") ?onButtons (list "noall" "Shapes" "Voids"))
        while((axlSelect)
        myshape = axlGetSelSet()
            foreach(myshapes myshape
            myvoidpath = axlPathStart( list(-3519.000:5586.000))
            myvoidpath = axlPathLine( myvoidpath, 0.0, -3519.000:5259.000)
            myvoidpath = axlPathLine( myvoidpath, 0.0, -3742.000:5259.000)
            myvoidpath = axlPathLine( myvoidpath, 0.0, -3742.000:5586.000)
            myvoidpath = axlPathLine( myvoidpath, 0.0, -3519.000:5586.000)
            axlDBCreateVoid(myshapes, myvoidpath)
            axlDBCreateCloseShape( myshapes)
I see warning in Allegro screen:
    E- Unfilled shape can not contain voids
    E- Database object is not a shape.
Can you  help me correct it.
Thank you.
Elek
  • B Bruekers
    B Bruekers over 7 years ago in reply to Jason Hsu +1
    Personally I would approach this in a different way; first create a rectangle polygon, then create a list of polygons which contain the 9 circles and 3 bars. Then do an axlPolyOperation with 'ANDNOT. …
  • fxffxf
    fxffxf over 17 years ago
     you cannot void unfilled shapes nor shapes on the keepin and keepout classes
  • DE202408202727
    DE202408202727 over 17 years ago
    You can't void an existing shape like that. To perform that task you should:
    1/ Extract the polygon of the existing shape (Use axlPolyFromDB).
    2/ Create a new open shape from that polygon
    3/ Create your void
    4/ Create the closed shape
    5/ Delete the original shape if all the above steps are successful.
    Dave
  • ELEKVN
     Tks, Dave
    You are good man
    Elek
  • luanvn81
    luanvn81 over 12 years ago
     By the way, I want to create a shape with void by text using axlText2Lines as following code:
     foreach(text AllTextsInDesign
                lines = axlText2Lines(text)
                ; flatten list
                flattened = foreach(mapcan x lines x)
                text_bBox = text->bBox
                ;enlarge bBox
                shape_box = list(axlMXYSub(car(text_bBox), add_shape_value) axlMXYAdd(lastelem(text_bBox), add_shape_value))
                create_shape = axlDBCreateRectangle(shape_box, t, layer_check, nil , nil)
                shape_ID = car(create_shape)
                foreach(path flattened
                            ; may return multiple polys
                            polys = axlPolyFromDB(path ?endCapType 'ROUND ?line2poly t)
                            ; create shapes in database
                            foreach(poly polys
                                        axlDBCreateVoid(shape_ID poly)
                                        ;shape_void = axlDBCreateShape(poly t layer_check nil nil)
                            );end foreach
                );end foreach
    );end foreach
     And the result is nothing happens(no voids created), please tell me how to repair code.(My allegro = 16.6)
     Thanks.
    Luan
  • DE202408202727
    DE202408202727 over 12 years ago
    Hi Luan,
    You  can only add voids to open shapes.
    Try this:
      foreach(text, textObjs
    ; flatten list
    text_bBox = text ->bBox
    ;enlarge bBox:
    ll = axlMXYSub(car(text_bBox), add_shape_value); Lower left corner
    ur = axlMXYAdd(lastelem(text_bBox), add_shape_value); Upper right corner
    ul = list(car(ll), cadr(ur)); Upper left corner
    lr = list(car(ur), cadr(ll)); Lower right corner
    shapePath = axlPathStart(list(ll, ul, ur, lr, ll)); Create a rectangular path.
    oShape = axlDBCreateOpenShape(shapePath, t, layer_check); Create an open shape ready to add voids.
    when(oShape
    foreach(path, flattened
    foreach(poly, axlPolyFromDB(path ?endCapType 'ROUND ?line2poly t)
    axlDBCreateVoid(oShape, poly); create voids in open shape
    );end foreach
    );end foreach
    when(car(parseString(layer_check, "/")) == "ETCH", axlDBCreateCloseShape(oShape)); This is only needed for shapes on an etch layer
    );endforeach
