  3. create clines with arcs using Skill
  • Views 15605
Ejlersen
Ejlersen over 17 years ago
Have anyone created clines with arcs using skill. I've read the documentation for axlDBCreateLine but it does not go into a lot of details.
Is they only solution around this to script "add connect" to add a series of cline segments where some are arcs?
Maybe axlMakeDynamicsPath is the solution, anyone with experience or samples? Can this command create it with a net attachment?
Best regards,
Ole
  • aCraig
    aCraig over 17 years ago
    Ole,
     Have you tried any of these - axlPathArcRadius, axlPathArcAngle, axlPathArcCenter?
     - craig
  • Ejlersen
    Hi Craig,
    Not before, but they work fine, so thanks for the tip.
    Best regards,
    Ole
